Reply 80 of 149, by Benedikt
root42 wrote on 2020-06-16, 11:40:Indeed. I *THINK* I put everything in there (except for the STM32), so you probably you need actually LESS.
@benedikt: any chance that in the future we might simply have three jumpers, to choose STM32/6581/8580?
Furthermore: Look at what I just got on loan - let's hope it still works!
A jumper based solution would not be that easy. Firstly, the STM32 version omits the entire clock divider circuitry, and secondly, the different SID variants need different filter capacitors, as well, not just a different supply voltage.
If you have a clean 12V supply, now, I expect the 6581 to work just fine, unless the chip itself is broken.
