First post, by LewisRaz
Hello all. I have finished setting up this system and would like to play on it but this bug is too annoying to deal with.
System specs:
Jetway 994AN-L
Slot 1 p3 850mhz
Voodoo 3 3000
512mb ram
windows 98se
And the Awe32. From this post: Re: Bought these (retro) hardware today
When playing midi or CD audio there is no problem. Only on sound files.
My motherboard does have a VIA chipset so I am concerned I am running into the same issue as this user: Sound Card or Motherboard
The only things I have tried so far with my limited knowledge of this tech is:
Different drivers (from vogons drivers instead of default win98)
Manually setting the IRQ and DMA that the card uses to "legacy ISA" in bios.
I have attached an example. The clicking fades away like an echo after making the sounds. In a game with many sounds the clicking is continuous.
Using the windows "ding" noise is the best way I can demonstrate it. The hissing is due to the aux cable passing audio to my main PC to record this sound.
Any advice or suggested settings to tinker with appreciated. I have quite a few other options but I enjoy the sound of this card.
    1.13 MiB
    clicking.mp3
    135.55 KiB
    32 downloads
My retro pc youtube channel
Twitter
Reply 2 of 5, by kolderman
There is a well known clicking bug on some SB16s, but I thought the vibra had the ringing bug instead. Have you tried changing dma ports?
And that mobo has the wackiest ide port layout i have ever seen. Engineer was drunk perhaps.
Reply 3 of 5, by LewisRaz
kolderman wrote on 2020-05-17, 18:48:
I have now fixed the AWE32 and I imagine the same will fix the Vibra although I wont be checking it.
I simply unticked the automatic configuration in the resources tab and set it manually. Works a treat now thankyou!
Twitter
Reply 4 of 5, by TechieDude
LewisRaz wrote on 2020-05-17, 20:31:
Wait, you actually fixed it? How? What settings did you use? I'm asking because I have the same exact card (and issue!)
Reply 5 of 5, by LewisRaz
TechieDude wrote on 2020-05-31, 00:46:
Yes, it works perfectly now (I use this pc daily!)
In device manager open the soundcard and go to the resources tab. Untick automatic configuration and enter manually or choose a preset with the correct settings. Windows had set the DMA to 5 or 7 (I cant remember currently) and it needed swapping to the correct one.
Twitter
