Gameport device not connected
First post, by SuperSirLink
Just recently finished building a Win98SE box with an Audigy 1 and SB16(nonPnP). I have a Microsoft Sidewinder Freestyle (added as a Microsoft Sidewinder game pad) connected on the game port bracket of the Audigy, but it shows as not connected.
The SB16 is not added to Windows, given I use it for DOS. I installed the VXD drivers for Windows and too my knowledge didn't install DOS compatible drivers for the Audigy, unless it did it automatically. I do have the game port bracket connected to the card and the Creative Audigy Gameport device in device manager. However there is an entry in device manager called Creative Joystick Emulation and it is using the normal default address for the game port, 0200-0207. If I remove that, Windows will not even let me add a game pad.
It haven't toyed around with this hardware since it was current and I fear I may be overlooking something obvious. Any thoughts that might point me in the right direction?
Reply 2 of 28, by derSammler
How fast is the CPU? The Sidewinder controllers fail to work if the CPU is too fast. I have them working on a P3 750 MHz, which is - according to the experience of some people - near the limit. That is due to the way they use the game port for digital communication, which is no longer reliable on fast systems.
http://retro-net.de/blog.html
Reply 3 of 28, by SuperSirLink
evasive wrote on 2020-05-20, 13:53:
So there are two separate sound cards each with an active game port in your machine and both live on address 200-207 then? You may want to disable one of them.
There are, but I have not added the SB16 to Windows, only use that when rebooting to DOS. Both of those devices showed up after installing the Audigy drivers.
Reply 4 of 28, by SuperSirLink
derSammler wrote on 2020-05-20, 13:56:
I am running a P2 350 at the moment. I am hunting down one that has an unlocked multiplier, this one is locked. But I could drop the FSB to run it at 233 and test...
Reply 6 of 28, by evasive
SuperSirLink wrote on 2020-05-20, 14:01:
Unless you disable things at a hardware level that stuff will still be visible and communicating at that port address, driver or not. You have to either disable one or set it to a different port address.
Reply 7 of 28, by SuperSirLink
evasive wrote on 2020-05-20, 14:10:
The SB16 is not a plug and play card and I don't think there is a jumper for the game port address, just to enable or disable it. I want that game port to be used in DOS. The memory address Windows assigned to the Audigy game port is 1000-1007. It assigned 0200-0207 to the Creative Joystick Emulation, it will not let me change that address space.
I just pulled the SB16 out completely, and the game pad still shows not connected. How can I determine if there are DOS compatible drivers that it installed for the Audigy? I don't understand why there is a "joystick emulation" device in hardware manager.
Reply 8 of 28, by austinham
I used to use a Sidewinder controller on a C2D system. a fast CPU is not the problem.
I suspect its ether a resource conflict or driver problem.
Reply 9 of 28, by derSammler
That's why I wrote "according to the experience of some people". Most people tell it stops working at an FSB of 100 MHz, which is certainly not true, however (my P3 is using 100 MHz FSB as well). But they *are* speed-sensitive, it's just still unclear how and to which extent.
Note that this applies to those using the game port in digital mode only. Those using MIDI (Force Feedback Pro and the FF Wheel) or USB are not affected by system speed at all.
Reply 10 of 28, by SuperSirLink
derSammler wrote on 2020-05-20, 15:20:
Hey at this point I will try anything. I will drop the FSB to 66 and see what happens.
Reply 13 of 28, by austinham
Did the midi game port cable get plugged in the right way on the Audigy ? or is it a Audigy se with the game port on the card?
Try removing the Audigy or SB16 and trying again. also try Sidewinder Freestyle drovers and not the Sidewinder game pad drivers.
Reply 14 of 28, by SuperSirLink
There is a power light on the Freestyle that comes on. The connector is keyed I believe, but will double check...
Its not listed, maybe that is the problem. But I didn't find any drivers specially for the Freestyle.
Reply 15 of 28, by derSammler
Ah, wait. But you did install the Sidewinder Software 3.x, didn't you? It will not work without it, as it has no fallback mode to work as an ordinary analog joystick/-pad (unlike the Sidewinder 3D and the Gamepad). It will also not work in DOS because of this.
Reply 16 of 28, by SuperSirLink
I installed this, but then removed it when I saw it was only putting the wheel software on it.
http://www.vogonsdrivers.com/getfile.php?file … menustate=25,24
I have an older basic 15 pin gamepad I can dig out and try too...
Reply 17 of 28, by lolo799
derSammler wrote on 2020-05-20, 18:42:
The Sidewinder Freestyle works perfectly in DOS, been using it for years.
Reply 18 of 28, by derSammler
In plain DOS, not in a DOS session within Windows? How did you manage to do that? I sold both of my Freestyles long time ago because they were not usable in DOS. Games either detected no joystick at all, or it would not calibrate, since it was stuck in digital mode.
I had the later one that came with the USB adapter, however. Could be that the earlier ones had a fallback mode, which was removed later to allow USB as an alternative. I think they did that with the Precision Pro as well.
SuperSirLink wrote on 2020-05-20, 19:30:
You need the software due to the digital nature of the controller. You can not select some other Sidewinder controller, since it will query its ID and since it doesn't match, it can never be connected. Get the Sidewinder Software 3.0 and install it.
Reply 19 of 28, by lolo799
In plain DOS, yes, with the Freestyle in analog mode, games just go through the usual joystick calibration routine.
I played old flight sims with it, like Wings of Glory, Xwing and Tie Fighter Dos collectors editions, racing games like Indycar, stuff like that.
I think there was only one version, mine has the usb adapter too, and i pretty much bought it soon after it was released.
