First post, by T-Squared
- Member
I'm aware of the Audigy 2 Driver hack, but does the hack work for the ZS, or is it only for Audigy 2 and 1?
I've tried to get the 2 ZS to work in DOS, but I believe the driver program does not detect it.
Audigy1 doesn't need it, ZS is irrelevant, just better analog circuitry.
T-Squared wrote on 2020-05-21, 02:49:I'm aware of the Audigy 2 Driver hack, but does the hack work for the ZS, or is it only for Audigy 2 and 1?
It works fine on the ZS, both under the Win98 DOS prompt as well as in pure DOS 7.1 (using the "Restart in MS-DOS mode" option from Win98).
Here's what I did to set things up. I might write up a proper step-by-step guide when I have more time since a lot of people seem to be asking about this.
