First post, by maverick85
Hi, I'm trying to play cd audio from the cd through the soundcard and out of the toslink. I understand that there are only vxd drivers for the card and that the check box is greyed out for digital audio in the cd drive section of the multimedia options in windows 98. Has anyone had any look in doing so? the sound is very crisp and clear using an external dac
I am playing age of empires 2 which has in game cd audio
ASRock 98
Win98SE Desktop
ASRock 775i65G R2.03
Intel Pentium E5800 3.2GHz
512MB DDR Dual Channel
Aureal Vortex 2 Superquad Digital + FiiO E17 DAC + E10C
ATi Radeon 9800 Pro 128MB
2 x SATA 120GB HDD's
1 x IDE DVD-RW
Reply 1 of 5, by PARUS
The Vortex 2 DSP is configured in its driver with absolutely separated digital output. I.e. all inputs from AC97 are not routed to digital output. I think if you'd use CD digital input on your card you could get CD Audio tracks on digital out. Try digital tract between CDROM and your Aureal card. It's two pin 2,54 mm step size cable.
Reply 2 of 5, by maverick85
PARUS wrote on 2020-05-22, 12:41:
I'm unable to find a CD digital input on this card. There are some pins on it which I can't figure out what for
ASRock 98
Win98SE Desktop
1 x IDE DVD-RW
Reply 3 of 5, by PARUS
maverick85, Vortex 2 has at least two digital inputs. First is connected to AC97 with its ADC and attached to analog mixer, second is attached to separated S/PDIF input. It can be used with CDROM or any other S/PDIF source. All you need is reveal on your "some pins" power +5V line and do not touch it in any case (you may damage your spdif sources). One of other pins is spdif input, try any pin with CDROM and you'll find it. Of course you should tune S/PDIF slider in Windows mixer.
Reply 4 of 5, by maverick85
PARUS wrote on 2020-05-23, 16:20:
I have female to female dupont cables, which I can connect to my dvd drive. But where do I connect the other end of the cables. Unlike the soundblaster audigy 2 zs, it doesnt have a CD spdif connector clearly labelled..
There are rows of pins on the aureal card (top right or bottom left) but I dont know where to connect the cables.. where is the ground and where is the +5v?
ASRock 98
Win98SE Desktop
1 x IDE DVD-RW
