Reply 41 of 158, by dreamblaster
not decided on colors, first small next batch will probably be green.
Some more tests : see attached files.
Thanks for your support !
Reply 42 of 158, by Joseph_Joestar
That sounds awesome!
EDIT - can you give an estimate of the dimensions? I'm wondering if it can fit on my Avance Logic ALS100. In centimeters please, for us Europeans.
Reply 43 of 158, by dreamblaster
dimension : 80mm x 60mm
Reply 45 of 158, by Joseph_Joestar
dreamblaster wrote on 2020-07-12, 12:18:
Looks good in terms of length. I am a bit worried though since my ALS100 has some rather tall capacitors below the wave table header, so I'll probably get one of your gameport to wave table adapters, just to be safe. That would also allow me to put this on the AWE64 and the YMF724 which is great.
Anyhow, put me down for one when you do the first batch.
Reply 47 of 158, by hard1k
Dream used Roland samples without permission 😀
Roland filed a lawsuit, and finally they settled everything. After that the GS logo appeared on many products with the Dream synths/ROMs.
https://www.eetimes.com/atmel-and-crystal-sem … oland-corp-u-s/
Fortex, the A3D & XG/OPL3 accelerator (Vortex 2 + YMF744 combo sound card)
AWE64 Legacy
Reply 48 of 158, by Salient
Count me in for one of those cards too!
Reply 49 of 158, by dreamblaster
Another quick demo : playing rise of the triad in DOSBox, and connected to Yucatan FX using midi interface : 'Goin' Down The Fast Way'
Reply 52 of 158, by keropi
kolderman wrote on 2020-07-13, 00:18:
Is there any point getting one of these if you already have a diamond monster 4mb daughter board?
no it will be the same thing
Reply 54 of 158, by keropi
I have made some Rise of the Triad in-game recordings with both the GMS963200B bank and a SC-55 mk2 - same machine same settings and recording system, same everything.
So everyone will be able to judge how close to the roland hardware this is and if it suits their needs.
There ARE differences of course - it's totally different sound engine and fx processors , different chipset in other words. So hear for your self 😀
Tracks are 192kbps mp3 files so the forum player can use them.
Reply 55 of 158, by keropi
and one last track - one of my favorites Havana Smooth , hope you enjoy the recordings!
Reply 57 of 158, by darry
keropi wrote on 2020-07-13, 20:12:
Thank you, will listen carefully when I get the chance
Reply 58 of 158, by 640K!enough
keropi wrote on 2020-07-13, 20:10:
There are definitely differences between the two; in particular, the Yucatan seems far more bass-heavy. Is that just the result of using that synth and sound set, or was that specifically one of the goals for the design? It seems a little excessive to me.
Reply 59 of 158, by keropi
^ nope it's all 9733's + bank result , card is built according to Dream's recommendations
