First post, by Digidreamer
- Member
Morning all,
i'm upgrading my T5710, starting a new project around the T5720 (Need more CPU Kick, aims are 3d card, decent sound (Prefer soundbalster) and working gameport for Microsoft Force Feedback wheel and Joystick), already fitted the IDE style PCI riser, using what I did with the t5710, already hit issues with the sound card
the CMI 8738 I was using, doesn't work, I have a newer CMI 8738 , with a shorter PCI connector(Cheap Chinese knock off, looks like no 12V Supply for the card) works, but doesn't have a working gameport (the board's not populated at the Gamport interface)
Has any one got anything cheap running on the T5720. £40 for a Yamaha is a bit OTT to find it doesn't work with my FFB game controllers I'm intending on using.
i'll attach photos later showing the diffrences between CMI 8738 cards I have.
also has anyone used the StarTech.com PCI1PEX1 PCI to PCI Express Adapter Card with a thin client, I have the kit to go from pci-e1 to dual PCI32 with external power so should get around any power restrictions set by the thin client by running cards externally. or am I going to hit the Bios whitelist issues.
may be we could do with a Thin Client Thread? info's scattered or is there already somewhere that caters for these machines
I Like Charity Shops, they're like steam and GOG but cheaper.
Windows 7 - HP730 Air cooled, 8Gb, GT1030
Windows 98se - Wyse V10LE 1.2Ghz, 1 Gb, 16Gb SSD
Windows 98se - Compaq Evo 550d SSF, P4 2Ghz, 1Gb, 60Gb(Partitioned)
Dos 6.2 - HP7510 512Mb, 4Gb
