OPL3 vs. ESFM vs. CQM vs. SBLive
Reply 20 of 35, by Joseph_Joestar
lawyerpepper wrote on 2022-02-25, 12:36:
Any chance of adding a Crystal 4236b or 4237b? I’m partial to Crystal FM, although the ESS does sound awfully good too.
I don't have any Crystal cards myself, but other people who do are free to post their samples here.
Reply 21 of 35, by Boomer
Great topic!
Is there possible make sounds from Yamaha OPL3 YMF262 chip and Yamaha OPL3 YMF289 chip?
This chips are common but kinda rare, there is very uncommon chip from yamaha own soundcard with OPL4 YMF278 chip that would be cool to hear in comparison.
Reply 22 of 35, by Joseph_Joestar
Boomer wrote on 2022-11-07, 10:13:
Great topic!
I do have some recordings of the YMF-262 chip as well.
As for the YMF-289, from what I understand, the YMF724 card has a version of that chip integrated inside its core, so these recordings should work fine for comparison purposes. Someone correct me if I'm wrong here.
Reply 23 of 35, by Boomer
Here is my records, first on the audiotrack is sb16 ct2890 opl3 ymf-262 and then sb16 ct2940 opl3 ymf-289b.
You can hear the bass whooming from ct2890 i don't know what to do for that, i quess its just a card feature.
I didn't hear big difference between cards so its just the sound is more brighter on ct2940. Do you?
pc specs
asus sp97-v
pentium mmx 233mhz
good aux cable and audacity record software
recording card sound blaster audigy fx sb1570, it is kinda good card for this.
edit:
Re: Sound Blaster 16 Yamaha OPL3's audios
Reply 24 of 35, by appiah4
Joseph_Joestar wrote on 2022-02-25, 13:18:
I can get around to this sometime next week if you want to add it to your thread. I can also do it for AD1816 if you also want Analog Devices FM.
Would you be kind enough to share the .MID files for the following:
Doom E1M1
Duke3D intro
Tyrian level 1
Transport Tycoon main menu
Reply 26 of 35, by appiah4
leileilol wrote on 2022-11-09, 06:39:
The mids likely won't do good as you'll miss out on the game-specific timbres and audio engines to make the comparisons relevant.
I doubt they exist for Doom and Duke3D.. The latter two, I do not know. I have Doom, Duke3D and Transport Tycoon so I can record from in game with those, but Tyrian I do not have. I guess I can find a warez copy from the usual places..
Reply 27 of 35, by Joseph_Joestar
appiah4 wrote on 2022-11-09, 06:38:
I never used external midi files. All my recordings were made in-game for the reason that @leileilol mentioned.
As she said, I'm reasonably sure that at least Duke3D has some extra stuff going on. Heck, even playing the test tune from the setup menu sounds different from what you get when running the actual game.
appiah4 wrote on 2022-11-09, 06:41:
Tyrian has been made freeware by the original developers. You can download a free copy from GOG as well.
Reply 28 of 35, by appiah4
Joseph_Joestar wrote on 2022-11-09, 07:08:
I can do this for CX4236, AD1816 and OPTi 82C391 if you are interested.
Reply 29 of 35, by Joseph_Joestar
appiah4 wrote on 2022-11-09, 07:15:
Sounds good.
If you host the recordings on your SoundCloud account, I will add the relevant links to the initial post in this thread.
Reply 30 of 35, by Bancho
I have a recording of the OPL3 (CT1747) from the AWE32 over SPDIF. Its from level 14 in Decscent (Europa Co2 Mine). It was recorded ingame. I think the FM Version sounds great, although the MIDI version does too!
https://soundcloud.com/techglitch81/descent-e … =social_sharing
Reply 31 of 35, by W.x.
How close to CQM or ESFM / OPL3 are the integrated soundblaster pro solution modes on some motherboards from around y2000?
Like QDI Kinetiz 7E? (AC97 codec?)
can anyone provide recordings of Doom1 and Duke 3d midi here, if he can record it?
Reply 32 of 35, by appiah4
W.x. wrote on 2023-12-06, 00:15:
VIA's southbridges up to VT8231 sound pretty accurate to my ears.
Reply 33 of 35, by GigAHerZ
ESFM is a beautiful superset of OPL3.
You may want to include Warcraft 2 into the list. It supports both OPL3 "standard" setup and also specialized ESFM setup. You may even compare ESS card with both setups to identify differences. 😉
Reply 34 of 35, by Joseph_Joestar
GigAHerZ wrote on 2023-12-06, 11:12:
Already did that in this thread.
I wasn't particularly impressed with how WarCraft 2 sounded on native ESFM, at least the main menu music. But other games like Heroes of Might and Magic 2 and Theme Hospital can utilize that functionality very nicely.
Reply 35 of 35, by Joseph_Joestar
PC Sound Legacy just published an extensive FM synth comparison between various sound cards in this video.
Well worth listening to if you're curious about the differences.
