First post, by tp1020
I have a CT1600 SBP2, and it has been working fine for some time but earlier today I noticed there was no music in certain games. I eventually discovered that digital audio worked fine, but everything to do with the FM chip seems to be broken. As an example I can hear the gunshots and "halt!" voice clips in Wolfenstein 3d just fine but there is no music or sound when I pick up items. When I tried playing a midi file i could hear very faint and distorted sound when the volume was boosted to the max.
Anyway, could a recap fix this problem? anything else I could try?
Reply 2 of 5, by PatchedUp
Is there any visible problems/damage to the card? Do all the caps look okay, no bulging ones, none have got a loose leg or anything like that?
If there are no obvious visible issues and the card is only semi-working, then a recap could be worth a try. Failing that it might just be one of the chips is on it's way out unfortunately
Reply 3 of 5, by Intel486dx33
tp1020 wrote on 2020-07-30, 20:28:
Disable the mic in configuration. Or just turn it off.
Reply 4 of 5, by tp1020
Intel486dx33 wrote on 2020-08-03, 21:40:
Is there a way to do this apart from lowering the volume in the mixer?
Anyway, the reason I'm looking at this again is not because I fixed it but I was able to try it on another motherboard in case that was the issue. It was not.
Here is a video showing the problem, the speaker is at max volume and you can barely hear the music:
https://youtu.be/-Cis_hzHaDc
Reply 5 of 5, by Thermalwrong
Hey I recently had a very very similar issue with my strange soundblaster clone card, it could make digital audio but FM audio was near silent. That turned out to be a faulty FM DAC, which was fixed when I replaced the 'SC802' with a regular YM3014.
Here's my experience with it: Re: Anchor Electronics - Media Concept 2.0 Souncard - SB 2.0 clone with real OPL2
You should be able to fix your card by swapping out the YAC512 at U20. Buuut, since the SB Pro 2 has a more standard OP-AMP configuration, you may also want to check/swap out the LM3403 OP-AMP at U12 if that doesn't resolve it.
