First post, by kataniel
Hello folks,
I recently started Dune2 on my 486 equipped with a Shuttle HOT-235 Soundcard (Opti82C930, SB Pro compatible) and a DB50XG attached to it. Unfortunately, the midi music is way to loud so the digital speech and effects are hardly noticable during gamplay. If I remove the DB50XG, the digital effects are roughly twice as loud as with the DB50XG attached and clearly noticable. Dune2 ignores the volume setting in OPTI's mixer control tool SNDINIT.EXE /V, so I don't have the option to use these mixer settings to adjust midi vs digital effects ratio. In addition, Dune2 doesn't offer volume control (as far as I know).
I already tried a second HOT-235 - same problem.
I also tried the patched SETUP.EXE for Dune2 1.07 to set different sound devices for music (DB50XG) and digital effects (SB Pro), but still the same: The music is way to loud.
I don't know what to try next. Any ideas?
Dell Optiplex GL5100 | Pentium 100 | S3 Trio64V+ 2MB onboard | 64MB EDO | WDAC2850 | FX810 | OPTi 82C929 + NEC XR385
Dell Optiplex 466LE | am486 DX5 133 | CL-GD5429 1MB onboard | 8MB FPM | WDAC2540 | FX400 | HOT-235 + DB50XG
