First post, by FreddyV
Hi,
As it is quite an achievement, I decided to create a new Post for the Tandy DAC with Mod Master.
As I now Know the DAC quite well, you can ask me questions on its usage.
So, Mod Master now Work on the Tandy DAC with Good Result on the Tandy 1000 TL/2:
22KHz (And a Little more) for 8 Channels
48KHz for 4 Channels.
I did some recording and here is the first video I published:
https://www.youtube.com/watch?v=9hCYbzV8Z8U
The mix speed is slower in the videos as I use an 8 Bit EMS Card.
I now modified Mod Master to use the "Standard" Memory in priority, but did not test.
