First post, by TMiN
Hey all, long-time lurker and fellow graveyard parts collector...
I recently purchased this AWE64 from someone on eBay. During install of the software I was experiencing issues with the sound bank memory. Oddly enough, the card was detected normally and seemed to function normally to a degree. Being that it was supposed to have some onboard memory, but was reporting in the SB software as being "0" available, I decided to pull the card and have a closer look. Sure enough, I found a burned/melted trace.
Is this common? Is this card done? repairable?
Thanks for looking.
Reply 1 of 4, by Tiido
It looks like someone connected memory expansion wrong and that caused a short and burned the trace out. Luckily the fix of repairing the trace with a wire should be enough to make things work properly again.
Reply 2 of 4, by cyclone3d
If it was like that when you got it, definitely ask for a refund.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 4 of 4, by TMiN
Tiido wrote on 2020-11-29, 22:14:
Thanks, I'll see if I can pull off that fix.
