First post, by ocdmonkey
Ok, so something weird I noticed after changing out the VGA card in my HP Vectra is that the Soundblaster card I have installed in there doesn't seem to be working properly anymore. Depending on the application it will either be barely audible, or only play certain MIDI instruments. Jazz Jackrabbit in particular plays maybe half the instruments of its music (the main music track is almost completely gone), and the (I'm guessing) sample-based sound effects are barely audible. In Windows 3.1 the startup/quit sounds were super quiet but when I played a MIDI file it seemed to play fine at a normal volume. I thought it was some weird incompatibility with the new VGA card but I swapped it out with the previous one and it was still doing the same thing.
I'm honestly kinda at a loss of what to do about this. It's not the first time I've had some weird problem with this computer either (I was replacing the VGA card because the one I had been using before refused to display color when using my powered VGA splitter).
