First post, by Extreme Assault
Hello
I just unzipped a listmus.pak file where supposedly the music files for Alone in the dark 2 are located, the same for Alone in the dark 1, the files follow this numbering 00000000.adl, 0000000a.adl, etc.
I have tried to play those files with the winamp adplug plugin and it does not work, I have tried the dosbox / dx / dx command and neither.
I have not found any converter.
I wanted to convert to midi so that I could hear the difference between Aitd2's FM sound and midi sound using a bank for coolSoft software.
Thanks
