First post, by matze79
i build a Pentium 60 1-2 Years ago and did not use it very often,
but i noticed Strange Problems with Soundblaster 16, 32 and AWE64.
Each one is making a Crackling Noise when Playing Mod Files with GLX and Terminal Velocity has Strange Sound too.
All Cards are working fine in other Machines.
Playing Mod Files with MOD Master does work fine.
So it seems something is wrong with 16bit Playback ?
Also Adlib Sound and most 8Bit SB Sound Titles working Fine.
DMA is conflict Free, and IO Addresses too.
It somehow remembers me of UM8810PAIO Soundblaster Issues if wrong BIOS Version is used.
Anyone run this issue ? changing ISA Speed to compatibility, disabling LPT etc did not Help
also removed every Card except for VGA and Soundcard.
Thanks
Matthias
Reply 1 of 13, by rmay635703
You aren’t the first to have sound card issues on a p60
https://www.experts-exchange.com/questions/10 … nder-Win95.html
Someone else here was having issues like this but not on soundblaster (can’t find thread)
Reply 2 of 13, by matze79
Hm, behind Paywall
GLX
modmaster.mp3
216.75 KiB
58 downloads
(Crackling)
Terminal Velocity:
TV.mp3
231 KiB
58 downloads
(High Pitch Noise)
Reply 3 of 13, by matze79
No Ideas ? 😀
Reply 6 of 13, by matze79
Anyway got around it, put SB in a Bin and use ESS1869 with X2GS now.
Reply 7 of 13, by cyclone3d
I have seen a few threads about this lately. The common theme was a Cirrus Logic video card. The fix was to load UNIVBE.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 8 of 13, by matze79
I have Elsa Winner with S3 86C375 and 4Mb
Reply 10 of 13, by matze79
Does not help at all.
Reply 12 of 13, by matze79
No, it does not have -5V and its also not needed.
I run no Card that requires -5V.
Missing -5V with Card needing it would cause Weird Sound in all Titles, not only a few specific ones.
Reply 13 of 13, by matze79
The issue really was the PSU, it had ripple current.
The Soundblaster did not like this.
I replaced some caps inside the Enermax PSU and it works again.
