First post, by Pickle
I picked up this card second hand. Cleaned it up with soap and water, dried it out. Tested it on a P200 MMX system and no issue. I also had another card an with an Avance + Yamaha OPL3. I dont care at all for the Opti chip OPL, but i was curious about the Qdsp. Also seeing that both cards worked with Unisound I thought I could use the Opti for midi and the Avance for SB16 and OPL. Seeing a thread here with others doing the same thing with 2 cards gave me hope.
At first I had some conflict with the parallel port (disabled it), but after some tweaking i had both cards setup with different resources.
I had the opti card outputting into the line in of the Avance card. I had the midi working with this setup once. I was just trying to see if I could have alternate adlib ports and then both cards were not being detected by unisound.
The Avance is working fine alone (but odd both cards were not seen when the opti was present)
Ive tried the opti in multiple machines with the same result.
I was hoping I just had a bad capacitor, so ive recapped the all the ones near the ISA connector. Ive also replaced a couple around the sound output since the caps tops looked odd. But I assume the rest will only effect sound output.
Ive tried using the multi-meter to find a short or a bad part. I measured the transistor like package (its a regulator). Im getting 12 V on both sides so I think it be ok.
The worst case situation is that something in the opti chip itself died. I do have another opti card with the same chip so theoretically I could transplant it. Although i only have a heat gun (not a temp controlled station). I think i could use that to get the chips off. Then i could use my soldering iron to reattach the new one. But this seems like a desperate last resort.
But im hoping to do some more voltage checks on the board first. Im also asking for help from anyone with ideas what could be wrong and some guidance where else to check.
Thanks!
Front:
https://imgur.com/3r12keD
