First post, by AppleSauce
Hey so I've been trying to adjust the volume of the gravis ultrasound I own , as by default it's too loud
and nearly blew out my eardrums ,
does anyone know how to lower the volume via the ultramix.ini?
It's one of the models with the onboard mixer , so I'm pretty sure it can be done in software.
I'd probably wanna lower it by half.
1.83 MiB
Reply 1 of 3, by Gmlb256
There's an utility called ULTRAMIX (the one I use is v2.10). If you have a version that supports the mixer chip you can reduce the volume.
For "Overall Output" (O command line switch) you can do it with the following parameter.
ULTRAMIX O-20
Which will reduce the volume by -20 dB. The range is from -56 dB to 0 dB and the changes will be saved into ULTRAMIX.INI. You can also check additional info with the "?" command line switch.
Reply 2 of 3, by AppleSauce
Gmlb256 wrote on 2021-09-17, 02:47:
There's an utility called ULTRAMIX (the one I use is v2.10). If you have a version that supports the mixer chip you can reduce t […]
ULTRAMIX O-20
Okay that seems to have worked , thanks a bunch!
