First post, by GL1zdA
Does anyone know the pin-out of the proprietary connector's on Titanium Fatal1ty (SB0880/SB0886) and Titanium HD (SB1270)? On the Titanium Fatal1ty it is used for the external bay, but there's nothing that can be used for the Titanium HD.
Someone tried to find the pin-out for the Titanium HD, but most of it is still unknown:
https://mrlithium.blogspot.com/2015/01/sb-x-f … jp2-pinout.html
https://www.avsforum.com/threads/finding-the- … ium-hd.1844161/
getquake.gif | InfoWorld/PC Magazine Indices
Reply 1 of 6, by Wanderer
Hello GL1zdA!
I was searching for this years ago. All I could find back then was the location of SPDIF out pins on SB0880 (attached), hope this helps somehow.
    133.78 KiB
Reply 2 of 6, by SScorpio
I'm not sure about the Titanium HD, but other X-Fi's share the same connector as the Audigy 2. Just like the SB Live and Audigy 1 share the same connector and the Live Drives are interchangeable.
Here's the mapping for the X-Fi and Audigy 2.
https://pinouts.ru/Audio-Video-Hardware/sb_au … xt_pinout.shtml
Edit: Note the comment at the bottom, if it's the same connect many of those things can't be enabled without a real Live Drive. There might be a work around but I've never seen one documented for the X-Fi cards.
Reply 3 of 6, by The Serpent Rider
You can't do anything useful with Titanium HD internal feature connector. Sure, probably can plug SPDIF, but there's regular Titanium for that.
Reply 5 of 6, by GL1zdA
SScorpio wrote on 2021-10-08, 23:26:
I'm not sure about the Titanium HD, but other X-Fi's share the same connector as the Audigy 2. Just like the SB Live and Audigy […]
This is the problem. What you posted is the original X-Fi pinout (the PCI version), like the SB0480 one:
339.01 KiB
X-Fi SB0480 PCB connector
These were using the "classic" I/O Drive:
19.26 KiB
X-Fi I/O Drive
The X-Fi Titanium cards (the PCIe ones) used a totaly different I/O Drive:
94.97 KiB
X-Fi Titanium I/O Drive
Finally, the X-Fi Titanium HD has a connector, but it was never sold with anything, that could be attached to it.
Wanderer wrote on 2021-10-08, 21:45:
Hello GL1zdA!
The Serpent Rider wrote on 2021-10-09, 00:29:
What I was hoping for was a MIDI out for the Titanium 🙁
Reply 6 of 6, by SScorpio
GL1zdA wrote on 2021-10-09, 20:51:
Wow, I never saw that thing before. It's pretty disappointing in its IO compared to earlier models.
If you're looking for MIDI out, your best bet is a USB MIDI Cable. They add MIDI in and out ports that are selectable in software and will work the exact same way as the MIDI ports on an older Live Drive.
The MIDI on the Live Drives actually has a problem with those mini connectors it uses. They are difficult to source, pretty much everything you'll find are AT to PS/2 keyboard adapters which are a different pin out.
