First post, by leon81
Hello.
I am new to the forums and I could not find a similar post.
I have a Roland MIF-IPC card that started acting weird. When I kick off Monkey Island the sound is very distorted and the music seems to be playing very slowly. The green light on the MT32 is on obviously.
I already verified everything else works fine by changing the card with the LoTech one that I have on another box.
The card looks rather simple, has 4 disk capacitors: "104 25V KCK", 2 1K resistors and 5 ICs and another component which I believe is a tantalum capacitor (??) - I ve attached an image.
Has anyone else experienced this problem and can point to common failures maybe ?
I was thinking desoldering the caps and measuring them to start with.
Thanks a lot
