Reply 20 of 21, by Pierre32
- Oldbie
midicollector wrote on 2023-08-27, 09:10:I have a Compaq 4704 whose motherboard contains a wavetable header, and the part replacement info for it lists a part number for a wavetable header, so I've been curious about the compaq wavetable for a while...
Until I heard it. It's bad. Really bad. I've attached Doom's E1M1 and some pics of it that I found online.
I have heard many worse. In fact I think the only difference between your ES689 and the widely liked ES692 is an effects stage. Run that puppy through some reverb and maybe a dash of chorus and it should be up there with the best of the onboard options of the era. IMO!
