First post, by stanwebber
i have found a couple references searching vogons about the possibility of using the win95 awe control panel in win 2000/xp to load soundfonts. apparently there was some fix or patch available maybe a decade and a half ago on a long deleted website.
i can find nothing else on the internet referencing this. could someone please confirm the existence of such a fix and maybe even a hint of what website it was available from as a starting point for a search on the wayback machine at archive.org. thanks
Reply 2 of 5, by stanwebber
i'm convinced this was a real thing, but i'm also starting to be convinced that it's now lost to the ages.
i also found reference to a winamp plugin that purportedly can load soundfonts that i can follow up on.
Reply 3 of 5, by Stretch
I found a step-by-step howto but I could only understand it with Google Translate http://sannata.org/articles/sb_awe64_xp_soundfonts.shtml
Win 11 - Intel i7-1360p - 32 GB - Intel Iris Xe - Sound BlasterX G5
Reply 5 of 5, by maxtherabbit
Stretch wrote on 2022-02-28, 04:13:
Wow thank you!
What really pisses me off, is I had tried almost this exact procedure on my own without any guidance - I got as far as loading the NT4 driver and AWE control panel, but it never occurred to me to use compatibility mode to make the control panel work
