First post, by PapaLaz
Hello there!
I’m trying to source a DB9 male to MIDI Jack (5-pin DIN) female cable for an old Music Quest 8-bit ISA card . They are like gold dust compared to the 15-pin old sound card cables!
Does anyone know any stockists that still build these, or is the only route to buy connector ends and solder pins etc?
Thanks,
Papa
Reply 1 of 8, by Cuttoon
PapaLaz wrote on 2022-03-09, 09:19:
Don't think that anyone ever build those except the original manufacturer.
But both ends being utterly trivial industry parts, a trip to the store or some one-figure clicks and five minutes of soldering seem like an awfully easy way to make gold. 😉
You might have to search for the card's pinout, though - the other end will be readily available.
I like jumpers.
Reply 2 of 8, by Pierre32
Welcome PapaLaz. One of the members here, keropi, sells modern clones of these cards (I have one and it's great).
http://pcmidi.eu/pcmidi.html
Music Quest MPU clone cards, anyone interested in them?
I believe the early models came with the adapter, but now they ship with a 3.5mm jack adapter instead. There is a provided schematic for the DB9 adapter though. Which leads to the answer you're after... I think you'll have to get one made up.
50.83 KiB
Reply 3 of 8, by keropi
yes it is exactly like Pierre32 shows, for the original MQ card you will ignore completely the right-most connector in the green square
remember the pinout is a solderside one - meaning you follow it with the solder side of pins towards you so it is easy to follow when you solder the cable
Reply 4 of 8, by PapaLaz
keropi wrote on 2022-03-09, 11:28:
Gotcha. So looking at the diagram, for a basic MIDI out cable from MQ I need to solder pins 6,2,1 on the DB9 to 6,2,1 on the 5-pin DIN? The other pins are not needed.
Reply 5 of 8, by keropi
PapaLaz wrote on 2022-03-09, 14:09:
yep!
Reply 6 of 8, by PapaLaz
Parts ordered for a solder-fest 🎉
The MQ card (see images attached) flags as running ok in MQDIAG dos app, on IRQ2. Do you think it will be 100% compatible with Roland MPU-401 games?
Reply 7 of 8, by keropi
yep you won't have any issues , what you have is a newer version that basically allows more IRQs to be chosen
everything you see here can be used for your card as well: http://pcmidi.eu/files.html
Reply 8 of 8, by PapaLaz
keropi wrote on 2022-03-09, 16:53:
Awesome! Thank you 👍🏻
