First post, by ThatIdiotCid
In an attempt to get this somewhat brief, I've got some questions (and a bit of confusion about those two products). I've got a MT-32 Pi for a MiSTER, but since it'll be later this year (if even then) that I might be able to build a vintage PC for DOS and some early Win 9x games, I've was wondering if either the MP32L or the X2GS + X2BOx would even be remotely useful when running games in ScummVM or DosBOX on my modern PCs?
The MT-32 PI for the MiSTER uses USB to connect the hat right to the "user port " (IIRC) on that unit, while the MP32L looks like it has a midi port. Could I use something like that Roland UM-ONE mk2 USBMIDI interface, and have ScummVM/Dbo x return the audio into those games, or would I need to just hook at a headphone to the MLP32L?
I really want a vintage PC so I can get Dreamblaster XSGS daughterboard, but last night I noticed that you could put that daughterboard into that little consolure as a standalone MIDI unit. The thing is, the only connections I noticed on it, were a mini-usb port, and then a headphone jack. Would I need to hook headphones to that too, or work ScummVM/Dbox bridge that audio back into the main game audio?
(Got a question about that Buran X3B, but I have a bad feeling it'll be the same issue).
If I'm totally off basis on this (which I'm expecting to be), just let me down gently. I'll pop up in the other channels, looking for "new" old stock, so I can build a 486/Pentium system with all the stuff I couldn't swing as a kid, since I'm mainly wanting to play all my old DO S games from back in the day. 😀
