First post, by Shponglefan
I'm looking for information on the Diamond Monster MX200 wavetable board that came with the card.
From what I can find, it was a 4MB board with licensed Roland samples. But I can't find much else on it. I'd like to get an original, but in lieu of that, I'm wondering if there are other wavetable boards that contain the same sample set? Or if it's possible to get something like a DreamBlaster and load the sample set onto it for use with sound cards w/ wavetable headers?
Pentium 4 Multi-OS Build
486 DX-33 with 5 sound cards
Reply 1 of 6, by RetroGamer4Ever
Any information about daughterboard of Diamond Monster Sound MX200?
You most certainly won't be able to get the original board. Just get the Dreamblaster X2GS, which is a descendant of that board and has a newer Roland GS soundbank.
https://www.serdashop.com/X2GS
Reply 2 of 6, by Shponglefan
RetroGamer4Ever wrote on 2022-03-17, 19:33:
I'm looking for the specific soundset specific to the MX200 wavetable board. If it's not otherwise available, I'll just hold out to hopefully acquire an MX200.
Reply 3 of 6, by RetroGamer4Ever
It uses a 4MB Roland GS soundset from DREAM, because it uses an old DREAM DSP, and you can't get the daughterboard these days or the bank itself, which was only available through DREAM's dev channels. According to the datasheets, DREAM had multiple GM and GS soundbanks for different memory sizes, going as high as 32MB, but specific information for those old banks is only available from DREAM itself and not openly distributed, as far as I can tell. The bank itself would probably be encrypted in the card memory, so you wouldn't be able to "get at it" without some serious effort, if you could even get a hand on the card, but there are other daughterboards from the late 90's-early 2000's that use the same GS bank because they use the DREAM chips. If you have the Yucatan FX board from Dreamblaster, it should be the same soundset.
Reply 4 of 6, by Shponglefan
RetroGamer4Ever wrote on 2022-03-17, 21:02:
Unfortunately I do not, and it looks like that was a limited run so none available.
The only other board of the era that I've seen that has the same chipset is the Turtle Beach CancunFX board for the Montego II. I'll add that to the list of cards to hunt for.
Reply 5 of 6, by cyclone3d
I have both the Yucatan FX and the original Diamond 4MB card.
The 4MB cards pop up every once in a while but they are usually priced super high.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 6 of 6, by RetroGamer4Ever
I don't know if this will be of any use to you, but here is a bank converted from the bank used with the Diamond and Yucatan boards. The name of the bank is "GSSBK320.94B".
Here is a PDF with some information and sound list....
http://www.studio4all.de/downloads/gssbk320tts_e.pdf
http://www.studio4all.de/htmle/main37.html
Here are some soundfont files...
http://jo.koan.net/WaMi%20Box%20Drivers/2000% … I%20Soundfonts/
It also turns out that there are thousands of the original ROM chips available through parts sellers, so anyone can throw together their own board, by pairing one with a compatible Dream DSP.
