Reply 21 of 31, by kode54
Did you reset the emulator first? Did you try both gm and gs reset modes? Also, are you using my midi_processing library to convert the loudness tracks to midi? (My library uses a novel conversion based on adplug and also does one thing the game only does for fm: portamento)
Reply 22 of 31, by Karmeck
kode54 wrote on 2024-04-05, 00:55:
I did, both resets as well. But, I tried the same midi with all my soundfonts. And the same difference is there. Even tried the demo in dosbox, same differens, compared to the recording.
Will do a recording. After this weekend.
But I think I lack some skill to identify the issue.
Reply 23 of 31, by EmperorGrieferus
Karmeck wrote on 2024-04-05, 18:52:
I did, both resets as well. But, I tried the same midi with all my soundfonts. And the same difference is there. Even tried the […]
Perhaps there's some SysEx bug in NukedSC that makes Asteroid dance sound weird because I had the same issue.
UPD: It was a version with messed up instruments.
Reply 24 of 31, by EmperorGrieferus
Dude, you downloaded the wrong version of the Asteroid Dance!
Reply 25 of 31, by kode54
Downloaded where? I can share the original .lds files, and my midi processing library and associated players can play them with their embedded GM mappings. Though you will need to send a reset to the midi device when done, since it leaves all channels with a full octave as the range for the pitch wheel instead of the default two semitones.
Reply 26 of 31, by Karmeck
EmperorGrieferus wrote on 2024-04-07, 00:15:
I did a GS reset (q, hold u, q, release u, w)
https://www.youtube.com/watch?v=iKZUyvwGkmQ
attached a recoding as there is clear differences in the beginning.
Reply 30 of 31, by Karmeck
EmperorGrieferus wrote on 2024-04-07, 23:28:
I tried to test EmuSC but it failed to load control ROM. Control ROM version is 1.21. Maybe I should use another version?
1.21 works for me. I had emusc crash on me, had to rename one of the rom files so I could change some settings. Like audio to win32.
Reply 31 of 31, by EmperorGrieferus
Karmeck wrote on 2024-04-08, 11:57:
Already fixed the issue. Though, EmuSC's not worth it right now.
