First post, by Shponglefan
- l33t
I have an Audigy 2 ZS that produces popping noises through speakers for about the first 30-60 seconds after booting into Windows XP (32-bit). After roughly 30-60 seconds the popping noises stops and the card performs fine.
I had a synthesizer that would produce distorted audio on initial 30-60 seconds, which turned out to be a bad capacitor issue. I'm wondering if something similar might be affecting the Audigy 2 ZS.
Physical inspection doesn't show any bulging or leaking caps. Though I know that doesn't necessarily mean there isn't an issue with one. There are a lot of electrolytic caps though and I'm wondering if it's worth trying to diagnose. Or if it's some other issue entirely.
I suppose I could always get another ZS 2 card, as it might be less hassle.
