First post, by haker120
I have simple yet annoying issue with MIDI sounds, or rather not hearing them in win98SE unless I'll launch autoexec.bat from windows itself then they load and work. How can I fix this?
My next issue is detecting AWE32 in games, this usually works but often I see AWE32 couldn't be detected. Under windows and DOS mode everything works but DOS window and AWE Control Panel have a problem (playback plays no notes unless autoexec.bat reloaded after windows started). I don't think 32MB RAM upgrade for the card itself causes this.
My autoexec.bat:
mode con codepage prepare=((852) C:\WINDOWS\COMMAND\ega.cpi)
mode con codepage select=852
keyb pl,,C:\WINDOWS\COMMAND\keybrd4.sys
SET SOUND=C:\SB16
SET BLASTER=A220 I5 D1 H5 P330 E620 T6
SET MIDI=SYNTH:1 MAP:E MODE:0
SET CTCM=C:\SB16\CTCM
C:\SB16\CTCM.EXE
SET PATH=C:\SB16\CTCM\DRV
C:\SB16\DIAGNOSE /S
C:\SB16\MIXERSET /P /Q
C:\SB16\AWEUTIL /S
My config.sys:
LASTDRIVE=Z
device=C:\WINDOWS\COMMAND\display.sys con=(ega,,1)
Country=048,852,C:\WINDOWS\COMMAND\country.sys
DEVICE=C:\SB16\CTCM.EXE
Reply 1 of 4, by Babasha
Some games in protected mode “kill” the preferences or adjusments of souncards and their TSRs. Create simple bat file with soundcard section and run in before starting next game.
Need help? Begin with photo and model of your hardware 😉
Reply 3 of 4, by Babasha
Create .bat file like soundon.bat with this lines:
SET SOUND=C:\SB16
C:\SB16\CTCM.EXE
C:\SB16\DIAGNOSE /S
C:\SB16\AWEUTIL /S
Run it before start next game 😉
