Reply 160 of 224, by heckyeah
Marmes wrote on 2022-06-20, 21:27:
Hello!
If there is interest in these boards, you can now start to contact us via email. First boards are ready and available.
Thanks!
Sent an email to Keropi. You aren't opening order forms?
Reply 161 of 224, by keropi
The usual order process will start when I receive the big box of cards sometime next week
atm there is a small stock that marmes has so we thought this can be available now for vogons members that want such a card
The bad news is that PCMIDI addons (and by extension the standalone pcmidi isa card) will not be available for the time being because they are affected by the chip shortage.
Once this gets resolved it will only be a matter of inserting the pcmidi addon to the headers on the card and it will work, nothing to solder or mod 😀
🎵 🎧 PCMIDI MPU , Orpheus , Action Rewind , Megacard and MK8330 soundcard website
Reply 162 of 224, by appiah4
I will be receiving a Behringer UCA222 in the mail today; that should make analog recording much less painful than my UMC22 where I have to equalize the gains on the stereo channels painfully every single time.
You know what that means? Yes, I will be recording a lot of games from my MK8330 in the coming days. So please list what you want to hear - not limited to games, of course, but for chiptunes you will have to send me the files. 😀
Reply 163 of 224, by Kahenraz
The Behringer UCA222 is excellent. This is what I do all of my recordings on. I have a fancier model with higher bit rate and dual inputs, but the UCA222 sounds perfect to my ears and is good enough.
Reply 164 of 224, by darry
Kahenraz wrote on 2022-06-21, 10:25:
Did you ever get a chance to look inside yours to see what chip it uses ?
Re: Choosing a good ADC for recording from MIDI synthesizers?
Reply 165 of 224, by Kahenraz
I got the gray one, which should have the TI PCM290. But I can check.
Edit.
It's a TI PCM2902. Here is the exact chip inside mine:
295.02 KiB
Reply 166 of 224, by darry
Kahenraz wrote on 2022-06-22, 00:02:
I got the gray one, which should have the TI PCM290. But I can check. […]
Edit.
Glad you got one of the good ones.
It makes sense with the good performance you are getting .
EDIT :
Anybody considering one those should be weary of getting one of those not based on the TI chip . This is one technical review of that "bad" variant . Earlier less formal reviews point in the same direction .
See https://www.audiosciencereview.com/forum/inde … er-uca222.2036/
Reply 167 of 224, by appiah4
darry wrote on 2022-06-22, 01:29:
Glad you got one of the good ones. […]
Edit.
EDIT :
I believe that the review is wrong. It has since been pointed out that the CoolAudio V2902 chip found in UCA222 (as opposed to the BB branded PCM2902 chip in earlier UCA202s, which was also pruduced under license as far as I know) is actually the same IC produced under license by Behringer's CoolAudio brand. There is virtually no difference between the two units.
Datasheets:
PCM2902: https://www.ti.com/lit/ds/symlink/pcm2900.pdf
V2902: https://mediadl.musictribe.com/download/docum … 2_DATASHEET.pdf
They are 100% identical down to every single electrical characteristic - the datasheets are essentially copy pastes of one another. Moreover, even newer UCA202 units come with the CoolAudio V2902, not BB branded TI PCM2902 chips. The issue here is that the PCM2902A as well as the V2902 (which seems to be a licensed clone of) share the same issue of phase shift at higher frequencies. This was fixed in PCM2902B onwards, but for V2902 I have no idea - it does not even have revision markings, I believe. Regardless, UCA202 and UCA222 units can come with PCM2902A/B/C or V2902 - it's a gamble.
I haven't checked mine, but I will. Are they easy to open up?
Reply 168 of 224, by Kahenraz
Two screws and you lift it at the USB connector which secures the board from moving with a rubber cable flex.
It's a piece of cake to open. There isn't a single plastic hook, clasp, or clip to worry about.
Reply 169 of 224, by appiah4
Kahenraz wrote on 2022-06-22, 10:26:
Just checked, it's the CoolAudio Y2902 clone inside mine.
Reply 170 of 224, by darry
appiah4 wrote on 2022-06-22, 17:18:
Well, there are a couple of possible explanations.
Maybe the review unit was an outlier.
Maybe some of the early production runs of the licenced chip were out of spec.
Maybe unit to unit variation is significant.
Maybe the ADC performance on licensed units is still good even if DAC is worse and that is what most users use.
Reply 171 of 224, by Kahenraz
It the case color gray or red?
Reply 172 of 224, by appiah4
Kahenraz wrote on 2022-06-22, 18:19:
It's red, and labelled UCA222.
Reply 174 of 224, by darry
Kahenraz wrote on 2022-06-22, 23:48:
You can compare it with my past recordings, so see how yours compares. I don't know if any variance will be audible, but it's an option.
Search my username with the keyword "midi".
I would gladly run some comparison tests between a TI and Coolaudio based variant if I could find a cheap sample of the latter . I have a MOTU M2 I can use to run some RMAA tests .
Anyway, this discussion about recording/playback gear should be transplanted elsewhere so discussion of the MK8330 can continue in this thread .
Reply 175 of 224, by keropi
I have received today a nice stock of brackets 😁
since all pieces have fallen now into place it is now possible to order a MK8330 soundcard from it's site
I will eventually update the site with the final version pics and more info as things progress
also keep an eye out for a ctrl-alt-rees review video coming soon! 😀
Reply 178 of 224, by appiah4
Not meaning to be spiteful, but I actually have a spare Voodoo 2 bracket I am holding on to in case one day I come across a card that lacks one 🤣
Reply 179 of 224, by keropi
Kahenraz wrote on 2022-06-27, 11:17:
How did you get these made? I still need a replacement bracket for a Voodoo 2.
Suggestions on replacing the I/O bracket on my Voodoo 2?
one needs to send a CAD file to a factory that does this kind of work and they make them for you
pretty sure there is a voodoo2 bracket on thingverse so you can print one - until you find a spare metal one
making a single bracket in a factory makes no sense cost-wise ...
