First post, by GabrielKnight123
I found this card but without the breakout box it is an MPU-IPC and from what I see it looks like its missing a jumper bank to set the IRQ and I/O address or is this MPU-IPC only set to one default setting, I read on Vogons the breakout box from the T version cant be used with this card because of different pinouts can someone verify this please.
