First post, by haker120
- Member
I have never configured it under Win95 DOS, not DOS Mode in Windows' window. I'm using Phil's reboot to MSDOS because I like it.
The thing is sound works under Win95's DOS but not right away and only in diagnose app. When I'm checking diagnose I have correct 220 next 300 (because collides with MPU-401 in Windows) and IRQ5 impossible to obtain. Next I'm turning app CTCU and after it aweutil which enables TSR and after that I can set values as 220, 300 (or 330, it works here now) 5 1 and 5, I take update settings and after reboot the same however without reboot I managed Rayman installer to scream perfect with settings: SBPro, 5 and 5, I know corect settings are anything Sound Blaster, 5 and 1.
How to finish configuring this particular PC? I just managed with forum help to set up Win95 with USB support now DOS.
I need to mention under DOS6.22 everything was fine but this PC is 233MMX, S3 Trio64V+ 4MB and Voodoo 1 4MB so I couldn't run some games that need Windows 9x. 😁
EDIT: I know how to configure all of this under DOS6.22 because no app says it's incompatible with Windows 3.11 and Win95's DOS mode.
