Reply 160 of 897, by igna78
ChrisTOTG wrote on 2022-11-25, 01:01:
Does the LT have Gravis Ultrasound support? Or is that what the Interwave chip does?
Let me answer your question: logically, without the Interwave chip, the Orpheus II card behaves like a "normal" (or rather super-equipped 😉 ) OPL3 sound card with SoundBlaster/SoundBlasterPRO/Windows Sound System compatibility and with intelligent MPU-401 functionality
So no Gravis Ultra Sound features
Reply 161 of 897, by Boohyaka
Indeed that's what the Interwave chip does. See the LT as an update of the Orpheus I where they implemented improvements planned for Orpheus II on the existing.
I just can't get enough of Keropi and Marmes stuff and can't recommend it enough. I'm also skipping this one as I am very happy with my Orpheus I and saving for the full-flavor Orpheus II 😀 I can't wait to read more news about it!
Reply 162 of 897, by appiah4
Interwave is the heart of GUS, so the LT is a non-GUS version of the Orpheus II that basically updates the original Orpheus with Orpheus II's hardware bug fixes and QOL upgrades.
Reply 163 of 897, by keropi
I wouldn't say OrpheusI had bugs - things are connected according to what Crystal envisioned and if they made windows drivers that allowed the yamaha OPL3 to be used things would not have to change in that regard.
All improvements are simply because of experience gained on using the chip and designing more cards in the meantime , just like everything in life you get better as time passes 😀
Reply 165 of 897, by appiah4
firage wrote on 2022-12-19, 08:41:
Great stuff! Do you have any sort of measurements regarding your performance on the analog side and improvement over the first Orpheus?
I believe the analog output circuitry is basically identical?
Reply 166 of 897, by ltning
How's it going with the OrpheusII anyway? I was hoping for christmas time but honestly with all the awesome retro hardware coming out it's christmas all year nowadays :D
The Floppy Museum - on a floppy, on a 286: http://floppy.museum
286-24/4MB/ET4kW32/GUS+SBPro2
386DX-40/20MB/CL5434 ISA/GUSExtreme
486BL-100/32MB/ET4kW32p VLB/GUSPnP/AWELegacy
~ love over gold ~
Reply 167 of 897, by keropi
there was no way to make it for xmas time so now the full OprheusII is an early 2023 thing...
there are no audio comparisons/measurement on output - but things should be better than the original model - but it would be splitting hair at this point and I am not even sure the difference will play any role whatsoever
Reply 169 of 897, by ltning
Boohyaka wrote on 2022-12-21, 14:25:
I didn't want to be an impatient ass and ask for news, but now that it's done, thanks for the update and still looking forward to it :)
Leave that to me. :D
~ love over gold ~
Reply 171 of 897, by appiah4
Boohyaka wrote on 2022-12-21, 15:07:
Haha, yeah now realize the implication of what I said. Sorry! Thanks for what you do tho 😁
Someone had to take one for the team 😓
Reply 173 of 897, by keropi
we are slowly getting there
codename "bigus cardus" is around the corner 🤣
Reply 176 of 897, by Kahenraz
This card would be attractive for combining a known good digital FX chip for Sound Blaster Pro, a genuine Yamah OPL chip, and working MPU401 (wave table or external). I think I read that some of the features are available on optical as well.
My impression on this is that it's very similar to the Orpheus 1 but with the added benefit of a Yamaha OPL, which would otherwise require a second sound card (and a second slot), which may not even be a compatible configuration.
I haven't tried it, but is it possible to disable the FM portion of the Orpheus 1 or confure it to a port other than 0x388 so that another card can be used instead? This is what I do in another machine where I use the OPL chip from an ISA card but the FM from a PCI card.
Reply 177 of 897, by Boohyaka
Kahenraz wrote on 2023-01-20, 21:59:
Not quite. Orpheus I and II have a true OPL3 chip. The main novelty of the Orpheus II is the InterWave chip, offering GUS playback capabilities on the same card.
With Orphinit, you can change the 0x388 address indeed, and even disable the OPL chip.
kinkong wrote on 2023-01-20, 21:52:
How does this compare to the MK8330 (ignoring MPU401 capability and price)? Would that make Orpheus II the go to for win9x?
Orpheus is an SB Pro compatible, with a true OPL3 chip, WSS support, wavetable and an optional PC-MIDI (Intelligent MPU-401). Its target is "early" DOS, as it has no SB16 compatibility. Still you can install it in Win9x, there are drivers for it and you will get sound. But if your focus is Win9x, there are better options.
MK8330 is more of a jack of all trade, with up to SB16 support, WSS, no real OPL3 chip but technically a 1 to 1 clone, and an optional PC-MIDI expansion. It will be useful in DOS, and in Win9x. If you have a heavy focus on Win9x with a bit of DOS on the side, I'd recommend the MK8330.
Reply 178 of 897, by IcySon55
Hmmm, something just came to mind @keropi. For my main DOS rig I'm using a fairly new SilverStone case. It has USB 3 and HD Audio connectors. I've already located a USB3 to USB2 adapter, but what I haven't found is a HD Audio to AC'97 adapter. Could such an adapter be optionally bundled with the Orpheus I/II/MK8330? I'd buy 2 if you made them available since I have the Orpheus I and will later be picking up a II. 😄
Reply 179 of 897, by Stevogamer
IcySon55 wrote on 2023-01-22, 03:34:
Not sure if this helps but modDIY sells these adapter albeit at a high price 🙁
https://www.moddiy.com/products/AC%2797-to-HD … pter-Cable.html
