First post, by FinalJenemba
- Newbie
Trying to get my CT3600 AWE 32 to work in DOS and it’s driving me crazy. I did a ton of research and I think it’s setup correctly. CTCM is working, if I run the diagnose utility it sees everything and all the sounds play just fine, 8 bit and 16 bit. When I run games they recognize is at an awe 32 and see all the ports no conflicts, and I’ve tried multiple configs just in case. But games simply won’t play sounds in SB16/AWE32 mode. They either freeze or no sound, usually just no sound. They do play back sound just fine in SBPro mode, but then what’s the point of using the AWE32?
I’ve tried it using both the 512K soldered ram and expanded to 2MB, again diagnose is fine either way, games don’t work. I genuinely don’t understand. Why would it work in diagnose and not work in games what am I missing???
Edit: It’s on a socket 5 Pentium 75 machine. 16mb of ram and built in Cirrus graphics
Edit 2: Just tested Adlib, Adlib also works fine
