First post, by Almoststew1990
Hi everyone, my Audigy 2 ZS is being a bit temperamental in a variety of motherboards so I'm looking to replace it and take the opportunity to upgrade.
I see the next card along is the X-Fi and like pretty much all creative cards there are loads of different versions.
Can anyone advise on what versions to avoid? All I'm really after is good signal to noise (assuming that's background hissing?) And EAX in my XP build.
I see the SB Z is later still but hopefully still has XP drivers? It's also PCI-e x1 but that should be fine in my XP builds.
Reply 1 of 11, by The Serpent Rider
SB Z don't have XP support. Any card based on X-Fi standard PCI PCB should be fine. For best analog sound quality you can pick X-Fi Elite Pro or Auzen X-Fi Prelude.
Reply 2 of 11, by Joseph_Joestar
Almoststew1990 wrote on 2022-08-08, 07:36:
It doesn't.
The last X-Fi model with WinXP drivers is the X-Fi Titanium SB0880 PCIe. That's pretty much the best card that you can get for WinXP gaming. Avoid the "Extreme Audio" versions since they don't have hardware EAX.
PC#1: Pentium MMX 166 / Soyo SY-5BT / S3 Trio64V+ / Voodoo1 / OPTi 82C930 / AWE64 Gold / SC-155
PC#2: AthlonXP 1700+ / Abit KT7A / Voodoo3 / Audigy1 / Vortex2
PC#3: Athlon64 3400+ / Asus K8V-MX / 5900XT / Audigy1
PC#4: i5-3550P / MSI Z77A-G43 / GTX 650Ti / X-Fi
Reply 3 of 11, by Pierre32
Joseph_Joestar wrote on 2022-08-08, 07:43:
Yep, make sure it has the EMU chip. I think the Extreme Audio is the only dud in the range.
https://en.wikipedia.org/wiki/Sound_Blaster_X … the_X-Fi_Family
Reply 4 of 11, by The Serpent Rider
You can use Audigy Rx (PCIe card) in Windows XP btw, which use Audigy 2 ZS/4 Pro chip.
Reply 5 of 11, by Sphere478
The Serpent Rider wrote on 2022-08-08, 07:42:
The auzentech x-fi might just be the best sound card ever made for pci in my opinion. It gets my vote 😀
Sphere's PCB projects.
Reply 6 of 11, by auron
if you think an audigy 2 ZS is temperamental, a PCI x-fi is about the worst thing to upgrade to. output quality would be a weird reason anyway as the audigy 2 zs output seems perfectly fine to me. all of these cards do suffer from bad capacitors around the voltage regulators though so that could be the reason for your problems (https://www.youtube.com/watch?v=jUcQkAmIv2g).
i've never liked the x-fi series for their weird 3-mode concept, and some games like ut2004 are outright broken on them. doom 3 also comes to mind, where supposedly the only chance to play that game with EAX support but without the visual twitch bug is to use a certain audigy beta driver. so unless you really want to play that handful of EAX 5 games, i wouldn't bother with an x-fi.
Reply 7 of 11, by The Serpent Rider
UT2004 has dedicated X-Fi patch, which use 64 Mb of sound card onboard memory for new samples.
Reply 9 of 11, by auron
The Serpent Rider wrote on 2022-08-08, 23:08:
yes, and it was garbage. this old thread basically mirrors my experience with x-fi and ut2004, except i tried both pci x-fi and pcie x-fi titanium: https://forums.guru3d.com/threads/ut2004-and- … -sounds.191198/
to be fair i will say quake 4 and bf2 worked alright on the pcie x-fi.
Reply 10 of 11, by Almoststew1990
Well I got an SB0880 but obviously as soon as I bought it my Audigy 2 ZS settled down and now works fine. I'll stick with this for the moment (I feel it's a better fit for my 939 system (and I'm going to be playing fear, doom 3 and Quake 4!) but will try out the X-Fi on a 775 system at some point.
Reply 11 of 11, by DrLucienSanchez
Is anyone able to test Bioshock with patch 1.1 on XP with an Audigy 2 ZS and the last official drivers please? I can enable EAX in the game, but when i have to restart for it to take effect, it reverts to EAX off again. I'be tried to manually set in the config, same issue, so unsure if an X-Fi is an actual requirement for it to run, as this may prompt me into purchasing an X-Fi.
Classic rig - MS6156 Ver 1.0 Bx7 Slot1 Motherboard - Pentium II Deschutes 400Mhz, 320MB PC100 RAM, 20GB SATA Toshiba 2.5 via IDE/SATA converter, Intel i740 8Mb AGP, Sun Microsystems 16" CRT Monitor - PN17J0 CRT monitor
