First post, by dave343
- Member
Hey all,
I finally got around to installing Under a Killing Moon onto my 386, using a SB16 1740 for audio. Problem is when I was setting up the sound and it did the setup sound tests, during the Digital Audio Test, the voice is 70% clear the other 30% is static and cracking. The Midi test performed about 95% clear only slight moments of static. I'm using Kingston Hyper X Cloud-II Revolver headphones.
I/O is 220h
Int is 5
DMA is 5
Specs are:
AMD 386 DX40
8MB -60
Cirus Logic 5429 ISA 1MB video
SB16 1740
CF Card 256MB
24x CDROM
I know this isn't the fastest system to be running the game on, and I could upgrade the system to any number of Pentiums but I was really hoping to use this 386 for the game. I only have a single AT case and so I have a bunch of other projects I'm using the 386 system for.
So a few questions:
[*]Is the Kingston Hyper X Cloud II just too much to drive for the SB1740?
[*]Is the 386 too slow for the Audio processing?
[*]The setup config is saying the video card is too slow and could be lagging the Audio as well.
[*]Could their be a hardware issue/failure going on with the SB1740? Doom seems to play fine but then that's not digital audio I guess.
Thanks in advance for the replies.
