First post, by DirtyGarry
Hi. Need help setting up the jumper on the sound card. The sound card works, is detected in the system, there is sound in both Windows and DOS, but the Gameport does not work. I don't know, maybe the gameport is broken, but most likely the jumpers are incorrectly set.
Maybe someone has such a card and knows how to handle it, or has a manual.
Thank you in advance.
Edit.
Finally, I found it. If anyone needs the jumper settings, I add a screenshot.
Source -
https://books.google.com.ua/books?id=Z2AJPpbX … 6mcd-01&f=false
