First post, by lowlytech
I have a Rev D Pas16 with the sony interface (not used). I have had a bit of trouble getting this card to work in my 486 DX4 100, but finally found my VLB I/O controller to be the culprit for constant freezes and either the native or thunderboard sections to not work reliably.
Seems my last current issue is with impulse tracker. It plays fine, no issues, but when I exit IT, the thunderboard section doesn't work. All adlib and SB is just dead. Wolf3d will show sound blaster detected, but no audio. If I reboot or I have found it I open say jazz jackrabbit which is setup to use the PAS it will then be corrected. Is there some PAS16 reset or initialization program to reset its state so to speak to avoid having to reboot every time I exit impulse tracker?
This is the only other issue I have found with my PAS16 setup. I have tried various versions of IT, but nothing changes. Wondering if it isn't in the driver file for PAS16 maybe?
