First post, by Riikcakirds
I connect my MU80 to the gameport of my Sb16 with a midi cable. The Sb16 uses dos environment values of P220 I7 D1 H5 P330 T6.
What I can't find out after searching and confused me is what is the IRQ value of the MPU401 on the SB16 gameport. Is it using IRQ7 as the MPU401 IRQ?
I ask because when I play Privateer, setup always asks for an IO address and IRQ when I select general midi for sound. It works seemingly no matter what IRQ I give it for MPU401, even IRQ 5 or 8.
I just wondered if it matters, and what is the recommended setting ( old forum posts say IRQ2/9 is most compatible for MPU401)?
