First post, by Riikcakirds
I'm new to using a GM wavetable card in DOS. Can't find any settings about reverb or chorus (I'm using a crystal CS9236 that supports both).
When you play a game with GM music, will it enable reverb/chorus etc depending on if the music author used reverb/chorus when they created the track. I know GM is standardized, so will this automatically be enabled as long as your card is GM compatible.
