First post, by matti157
As per my title, I am using the Audigy SB0090 on a computer running Windows 98
In Windows playing a midi file on my Roland works fine
If I open a dos window instead the sounds are played from the card itself and not from the external device. I am trying with the dosmid player, but it does this with games as well.
Obviously I installed the DOS drivers for the audigy (which emulate the sound blaster 16)
Any ideas?
Reply 1 of 3, by Joseph_Joestar
I don't think this is possible in pure DOS on SBLive/Audigy cards.
Under Win9x you can of course select your preferred MIDI device using Control Panel > Multimedia > Audio > MIDI Music Playback, but nothing similar can be done in pure DOS.
Reply 2 of 3, by Gmlb256
It really depends on the sound card driver. By default, the selected MIDI device in Multimedia Control Panel won't emulate the MPU-401 interface for DOS applications within Windows.
For some reason people still doesn't get it. 😒
