Reply 21 of 22, by Yoghoo
- Member
I finally gave up after trying some other things like changing speakers etc without avail and thus replaced the X2GS with a MP3L (an external MT32 / Soundfont compatible synthesizer module). This works perfectly.
Then I put the X2GS in another PC which has an Orpheus I card. And big surprise: the exact same problem (so also very low volume). I now used 2 very different PC's and 3 ISA sound cards all with the same problem.
I really don't understand what the problem could be. If anybody else had some ideas left pleas let me know.
Reply 22 of 22, by dreamblaster
This is really strange. The returned X2GS was tested and had normal volume when testing here. Are you sure they didnt get mixed up ?
I can send you yet another one, i will pm you.
Thanks for your support !
