First post, by anetanel
I'm gathering the parts for a card, using the BOM file in Mouser, but there are 2 items that are marked as obsolete, so I'll need replacements.
1. The 15 pin D-SUB socket (152-3415)
2. The amplifier chip U5 (512-LM324AN)
I tried looking for a replacement DSUB connector by selecting all the attributes and looking for similar, and the search came up with 20 items. Can I just grab the cheapest one? 😜
And can the amp chip be replaced with this one: https://www.mouser.co.il/ProductDetail/Texas- … i7hHRxlkw%3D%3D ?
I noticed that it have a bit different "Output Current per Channel" value of 20mA, vs 40mA in the original part.
(I opened an issue in the github repo, but I'm not sure that it is still being maintained)
Reply 1 of 3, by Benedikt
anetanel wrote on 2023-03-09, 08:47:
You can use the cheapest part that is genuinely equivalent. Make sure to check the position of all pads, including mechanical pads, relative to the edge of the board.
The LM324 OpAmp is a rather generic part. The exact manufacturer is largely irrelevant because circuits using such a chip are usually designed with component substitution already in mind and do not rely on the minor differences.
Reply 2 of 3, by matze79
LM324 is used in a lot of devices.
Pretty sure there be still a lot of those around even in 20 Years.
Its chip design from 70s
Reply 3 of 3, by anetanel
Thanks.
I actually got a response in the git repo as well, and he even updated the BOM.
It seems that for the DSUB, one critical dimension is the distance of the mounting pins from the edge of the board, which should be 9.5 mm.
Looking at the datasheets of the part I found, it seems that I'm all good 😀
https://b2b.harting.com/files/download/PRD/PD … 9804DRW001C.pdf
EDIT:
Actually I see that the updated BOM has a different, even cheaper DSUB. Hurrah!
