First post, by ikethefox
Under Windows 95, Onboard OPL3 on my Reveal Sc400/Aztech Sound Galaxy Nova 16 conflicts with each other, is there any way to fix this, I can't find anywhere else that someone has had these issues.
I have tried the VOGONS sourced drivers from Reveal and it makes the conflict worse.
Reply 2 of 3, by vstrakh
By that dash you're indicating the same card under different names (Reveal/Aztech), or you're saying you have two cards, one is Reveal and the other is Aztech?
Do you have Adlib Gold card installed, as implied by the error message?
If you had Adlib Gold installed at some point (but there is no card now), and its driver now mistakenly recognizes Aztech OPL3 part as the Adlib Gold part, then you should just uninstall Adlib Gold drivers.
Reply 3 of 3, by Tiido
You can just delete the OPL3 device from device manager, it most likely was detected by windows during installation at some point due to the chip being visible as is and as a result got included in device manager, even if it is actually part of something other. DOS games will see the chip regardless and windows stuff simply uses what the Aztech driver allows them to talk to.
