MUS-1099
First post, by scroeffie
iam collecting parts for another soundcard build ! the bom list says this .22 uF Ceramic Capacitor do you see the dot infront of 22 ? is that 22 uf or 0.22uf ?
C1 10 uF Tantalum Capacitor
C2 .1 uF Ceramic Capacitor
C3 .1 uF Ceramic Capacitor
C4 .1 uF Ceramic Capacitor
C5 .1 uF Ceramic Capacitor
C6 .1 uF Ceramic Capacitor
C7 .1 uF Ceramic Capacitor
C8 .1 uF Ceramic Capacitor
C9 .1 uF Ceramic Capacitor
C10 .1 uF Ceramic Capacitor
C11 680 pF Ceramic Capacitor
C12 680 pF Ceramic Capacitor
C13 680 pF Ceramic Capacitor
C14 680 pF Ceramic Capacitor
C15 .22 uF Ceramic Capacitor
C16 .22 uF Ceramic Capacitor
C17 100 uF Electrolytic Capacitor
C18 100 uF Electrolytic Capacitor
C19 100 uF Electrolytic Capacitor
C20 100 uF Electrolytic Capacitor
C21 100 uF Electrolytic Capacitor
C22 100 uF Electrolytic Capacitor
C23 .15 uF Ceramic Capacitor
C24 .15 uF Ceramic Capacitor
Reply 1 of 38, by Jo22
I guess it's 0,22 µF (220 nF). Simply because ceramic types aren't that big normally.
Over 1 µF (1000 nF) it's usually electrolytic caps.
Reply 2 of 38, by scroeffie
any one can help me with the audio connector has allot of pins dont know where to buy these type or whats it called
Reply 4 of 38, by Pierre32
scroeffie wrote on 2023-06-04, 14:34:
This might be helpful from the original thread:
"I also put the 3.5mm jack on. It fits, but mine only has 3 of the 5 pins. The other 2 holes don't seem to be connected to anything on the PCB."
"The footprint for the 3.5mm jack has extra holes because the jack I used happened to have a built-in switch which is not used in this case. The jack you have should work fine unless the pinout of the jack happens to be different (which is doubtful, pinouts for these types of jacks appear to be pretty standard.)"
https://forum.vcfed.org/index.php?threads/cre … er-clone.60705/
Reply 5 of 38, by Scali
You have to be careful when selecting the jack. There are various heights available. The ones where the jack is flush with the PCB will sit 'too low' for your ISA bracket. You'll want one that is a bit higher.
Reply 8 of 38, by Scali
scroeffie wrote on 2023-06-13, 10:33:
does the card work with out drivers because my 386 is not seeing the card
There are no drivers. Software that supports the card can either autodetect it, or you need to run some setup/install utility to manually set the correct base address.
Note that autodetection in many games is rather limited, if you also have other sound cards in the system, it will probably never bother to detect the CMS/GameBlaster.
Reply 11 of 38, by appiah4
scroeffie wrote on 2023-06-13, 12:39:
i got the card to work iam not impressed i like the adlib clone sound way better
Not sure what you expected from a stereo square wave generator..
Reply 12 of 38, by root42
Listening to some samples on Youtube could have saved you some bucks. 😉
YouTube and Bonus
Reply 16 of 38, by scroeffie
iam trying to get sound with paku but so far nothing works i have sound in other games
i have set adres to 220 on the card pins
Reply 19 of 38, by Jo22
There's a DOS utility that let's you play music of various platforms. It supports CMS, too.
SBVGM (DOS) VGM Player
Creative had one, too.
http://www.vgmpf.com/Wiki/index.php/Creative_ … MS_Music_Player
Better tunes for CMS are Silpheed's credits tune, Monkey Island intro, Ultima VI..
The latter also supports Innovation Sound Standard (SSI-2001),
a rare music card for PC based on a C64 SID chip.
Maybe you enjoy making one of them, too. The replica was being worked on here at Vogons, too, I remember.
