First post, by 640K!enough
In a recent discussion, Marmes asked me to look into the reason that Impulse Tracker refuses to work with Orpheus boards (other than the InterWave on Orpheus II). The result of that is a revised WSS driver that takes a different approach to detecting the hardware.
The "problem" with the original drivers is that they either probe a limited set of I/O addresses (that are not appropriate for the cards in question), or expect to find the configuration interface of the original Microsoft design. All of these approaches fail on Orpheus. The simplest solution was to start with the original GUS Max driver (which uses the on-board CS4231 CODEC), and replace most of the detection routine. The resulting driver is attached.
The original port probing is (mostly) gone, and we instead rely on the ULTRA16 environment variable set by ORPHINIT (when invoked via ORPHEUS.BAT) and the installation routines for the original GUS 16-bit daughterboard and GUS Max. If it doesn't find it, or it's obviously invalid, "detection" will fail. Any IRQ line or DMA channel supported by the hardware should work. I/O addresses are currently limited to 12-bit (FFFH or less), which should be workable for most current hardware.
To use the driver, simply de-compress and copy it into your IT directory, then IT will have to be invoked with IT /sITCS.DRV.
This has been tested and confirmed functional on Orpheus and Orpheus II LT. Additionally, it should work on any card bearing an AD1848 or CS423x or compatible (Ensoniq Soundscape series, GUS PnP, GUS Max, GUS with 16-bit daughterboard, Audiotrix Pro, original Windows Sound System board and many more). For those whose installations don't define it, it should be as simple as setting an environment variable before running IT, as follows:
SET ULTRA16=base_address,playback_DMA,IRQ,0
The base address is the actual CODEC address, not the control/configuration port; this is often 534H by default. As an example, for Orpheus one would typically use SET ULTRA16=534,1,5,0 (or similar).
Depending on the sources you read, there is some disagreement about the format of the last part, but this will nonetheless work most of the time.
In my testing, playback quality was generally very good, and any problems appear to be related to IT playback bugs. In all honesty, I haven't (yet) changed anything other than the detection routine, driver name and mixing rate, so I don't expect to have introduced any new problems. Of course, I'm open to feedback and discussion, if anyone has problems.
    itcs.zip
    9.26 KiB
    48 downloads
    Impulse Tracker Crystal WSS driver
Reply 1 of 8, by keropi
thanks for sharing and for the hard work 640k!enough !
it works great for me and I could not detect any anomalies with the MOD files I have - nothing fancy though , mostly amiga game rips
🎵 🎧 PCMIDI MPU , OrpheusII , Action Rewind , Megacard , MK8330 and 🎶GoldLib soundcard website
Reply 2 of 8, by 640K!enough
It wasn't anything particularly difficult, but I think it makes it easier to get the software running on such cards.
For those who don't like drivers that are not part of the original distribution, the other option (meaning you don't need anything more than the latest official release; no third-party driver) is to specify the configuration on the command line, as in:
IT /sITGUSMAX.DRV /Ax /Iy /Dz
Where:
x is the CODEC base address (hexadecimal)
y is the CODEC IRQ
z is the playback DMA channel
Reply 3 of 8, by Joseph_Joestar
Nice work!
A suggestion, if I may. Rename the topic title to "Revised WSS driver for Impulse Tracker". In this day and age, very few people will associate the IT abbreviation with Impulse Tracker, even here on Vogons.
PC#3: Athlon64 3400+ / Asus K8V-MX / 5900XT / Audigy1
Reply 4 of 8, by 640K!enough
Joseph_Joestar wrote on 2023-05-31, 06:08:
Nice work!
That's a fair suggestion; done.
Reply 7 of 8, by digistorm
I have no need for this myself, because I have an original GUSpnp card, but are you aware that there is also a .mmx driver for the codec? If you CPU supports MMX it provides much higher quality mixing (the default mixer is not very good) and it supports the resonant filters of the .IT format.
