First post, by DOS Retro
I have a Sound blaster AWE32 (model CT3910)
I want to install this card in DOS 6.22 and use the onboard IDE interface for installing CDROM Drive.
Everything is installed in a AMD 486DX2/66 with 16MB of RAM.
What sounddriver (diskette) should i download to make the card work in DOS? An installation disk would be nice, so i don't have to make my own settings in autoexec.bat and config.sys
What CDROM driver is the best to use?
Do i have to change/make settings to make the IDE Interface work?
Thank you in advance 😀
161.34 KiB
Reply 1 of 2, by mkarcher
DOS Retro wrote on 2023-07-15, 10:05:
Use a recent version of the basic sound blaster drivers, distributed as self-extracting ZIP archive called SBBASIC.EXE. It extracts an installation program,
that handles all necessary adjustments to those config files.
The IDE interface on the CT3910 is controlled by jumpers only. To enable it, make sure that the IDEDIS jumper near the IDE port is not set. There is a table printed on the card that instructs you how to set the IDEIO0 and IDEIO1 jumpers. If you only have a single IDE channel in that system yet, I recommend you to use the default "secondary channel" base address 170h. Set IDEIO0 and don't set IDEIO1 for that. The conventional IRQ used in conjunction with base address 170h is IRQ15, so set the IDEIRQ jumper to the position labelled "15".
In my experience, any usual DOS IDE CD driver just works, so I can't recommend a specific one.
Reply 2 of 2, by JayAlien
Have a look here
http://vogonsdrivers.com/index.php?catid=7
You likely need this one:
Sound Blaster AWE32 Installation Disks - DOS/WIN3.11
386sx25 SBP2 2M
P75(486) SB16 8M
P133 S3 Vir DX A64g 32M
P233MMX R128Pro A64 64M
Pii400 TNT2 Live! 128M
P3-1G V5 M80 256M
P3-1.4G R8500 A1 256M
A3200 9700Pro A2 512M
X6800 X850XT A2ZS 1G
E8600 X1950XTX Xfi 2G
QX9650 3870 Xfi 2G
i7-975 GTX570 Xfi 3GB
