First post, by appiah4
- l33t++
I have a CT1740, and it has an issue with the volume potentiometer. There is no sound on the right channel unless I wiggle/tilt the potentiometer until there is. I'm guessing some oxidation is at work here, should I just spray some contact cleaner and be done? Or should I completely replace the potentiometer? I have one left over from back when I built a Snark Barker, but I'm not sure it should be necessary..
