First post, by wargrip
Hi!
Apologies if this has already been asked - found some very old posts but they refer to parts that are no longer available or to slightly different equipment so thought I would get a fresh take.
Here is the situation... I have an AWE64 Gold which has the standard Midi/Joystick DB15 combo port. I also have a MT-32 PI which I originally bought for my MiSTeR but am no longer using it - it only has USB-in since this is how it was designed to connect to the MiSTeR originally.
I am looking to now use the MT-32 (USB INPUT) with the AWE64 Gold for old DOS games where appropriate but am struggling to find the chain of connectors and cables that go between these two devices. I can get hold of a Roland Um-One MK2 which has USB on one side and 2 x Midi on the other - my understanding is that this would be the part that plugs into the MT-32 USB port - leaving two midi connectors on the other side (am I correct that I need a cable like this?)
That leaves me with the gameport on the AWE64 card and the two midi cables on the Um-One MK2. My assumption is that I then need something like the DB15 to gameport adapter from Serdashop but unfortunately this does not provide a breakout for a joystick so I can't play games like Wing Commander (which requires the use of the joystick port for both midi and as a gameport simultaneously).
After all that, I guess my question is am I on the right track and is this the simplest way to get the AWE and the Mt32-Pi to work together or is there a neat trick I'm missing - and is there an alternative to the serdashop option where I could use my joystick and midi at the same time? I think my dream device would be one of those gravis gameport midi breakout boxes which I would be willing to pay a lot for but they seem to have disappeared off the face of the earth.
Sorry if these are some dumb questions - still learning a lot as I go! Thank you!
-grip
