First post, by Shponglefan
I'm trying to compile a list of sound cards that support MPU-401 intelligent mode. Included are any cards with audio out in addition to MIDI interface support. I'm excluding MIDI interface cards that don't have audio capabilities.
This is the list I've compiled so far:
Ensoniq Soundscape S-2000 (somewhat compatible?)
Roland LAPC-I
Roland LAPC-N
Roland MPU-401AT
Roland SCC-1
Roland SCC-1A
Orpheus I
Orpheus II
Orpheus II LT
PCMIDI
Any other sound cards that support MPU401 intelligent mode?
Pentium 4 Multi-OS Build
486 DX-33 with 5 sound cards
Reply 1 of 8, by badmojo
The Ensoniq Soundscape isn't properly intelligent mode compatible, it just does some trickery to make it a bit more compatible than your standard UART MPU-401. It doesn't work with Gateway for example.
Reply 2 of 8, by Shponglefan
badmojo wrote on 2023-09-14, 23:59:
Good to know. I haven't tested it personally yet and am relying on info I've seen online.
I'm working on a build to include an S-2000, so I may run a test suite of a intelligent mode related games and see which sound correct.
Reply 3 of 8, by Jo22
From what remember (vaguely), quite a few games can be made run if an "ACK" (acknowledge) response is received from the MPU-401.
I suppose that's what some semi intelligent mode compatible soundcards do.
Once the intelligent features (metronome etc) are really being used, the games nolonger work as intended.
Reply 4 of 8, by Joseph_Joestar
I think HardMPU qualifies as well.
Also, some configurations of the MK8330 had PCMIDI as an add-on.
Reply 6 of 8, by Pierre32
Others that have come up in my travels (compatibility mileage may vary):
Music Quest MQX-32
https://www.jstor.org/stable/3680927
CMS-401
Questions about a CMS-401 MIDI card
MIDIMAN MM-401
MIDIMAN MM-401 - Not 100% Roland compatible
Reply 8 of 8, by megatron-uk
Midiman MM-401 doesn't work with Gateway. It's a good card, but it's just not quite fully compatible.
https://www.target-earth.net
