First post, by sndwv
I have a real SC-50 for use with my main PC, but I recently built a portable retro game PC and was wondering if there are any projects or options out there to build a 'portable Sound Canvas', a small box that can connect via USB as an external MIDI device for instance.
I think MT-32 emulation is in a pretty good place, but I haven't really found a satisfactory solution for GS / GM (and specifically the SC-50 sound) yet. There isn't one single 'fire and forget' soundfont that fits the bill (unless there is one now?), and I've dabbled with Roland's Virtual Sound Canvas in Windows with varying degrees of success- when it works it's great, but there are many issues with it loading wrong presets or (not) resetting when it should- for me at least.
Is there something out there that does this? Pre-built custom hardware, or Raspberry Pi-based? Something that runs virtual instruments or Virtual Sound Canvas internally? I also noticed Serdaco sells add on cards and external devices with licensed Roland sounds, but not something that really fits the bill as far as I can see.
Edit: my idea to look for a hardware solution is that this portable PC runs both Windows and Batocera, and both OSes can handle external MIDI attached via UM-One or similar. But maybe I'm looking at this from the wrong perspective.
Reply 1 of 22, by Tempus
There’s a portable Sound Canvas. The SCP-55. Requires drivers and a PCMCIA slot.
Akumajō Dracula: Belmont's Theme Roland MT-32 | Yamaha YM2151
Reply 2 of 22, by sndwv
Tempus wrote on 2024-01-16, 15:35:
Oh, that's really cool. Didn't know these existed. If not for this build I might dig up an old laptop for one. They are rare though, it seems.
- As far as I can tell SFF Optiplexes don't have PCMCIA slots or headers.
- I see that enclosures that convert PCMCIA cards to USB exist. Would that work?
- Any idea how OS support is for these, considering drivers are required? Any chance of getting it working past Windows 95-98? I think I might have an old XP laptop kicking around.
Reply 4 of 22, by Spikey
There's also a Roland PMA-5, a handheld Sound Canvas (sorta) which is hard to define exactly but at a minimum is a SC-50 with some SC-88 and other patches added in as well. I'm guessing it like any SC-88 and beyond isn't faithful to the SC-55 sound, but I haven't owned one or heard many examples.
Reply 5 of 22, by SuperDeadite
Dreamblaster X2GS would be good enough for most people.
CM-64, CM-500, SC-55MkII, SC-88 Pro, SY22, TG100, MU2000EX, PLG100-SG, PLG150-DR, PLG150-AN, SG01k, NS5R, GZ-50M, SN-U110-07, SN-U110-10, Pocket Studio 5, DreamBlaster S2, X2, McFly, E-Wave, QWave, CrystalBlaster C2, Yucatan FX, BeepBlaster, SuperOctet!
Reply 6 of 22, by lolo799
sndwv wrote on 2024-01-16, 17:40:
Oh, that's really cool. Didn't know these existed. If not for this build I might dig up an old laptop for one. They are rare tho […]
Pcmcia to usb enclosures work only for storage.
Scp-55 has official drivers for dos/win3x/win9x and 3rd party support for a really old version of linux.
For XP you better use a PMA-5 and a usb to midi adapter (or a serial cable) as Spikey wrote.
Reply 7 of 22, by sndwv
SuperDeadite wrote on 2024-01-17, 10:21:
Yeah, I've been looking at those, but I don't really understand what I'm looking at- are these daughter boards to a (specific) host card? Or can they connect as an external device? And as for the Roland sounds, are these similar to a soundfont, or to Microsoft GS wavetable software synthesizer, which is also Roland-licenced but sounds nothing like a Sound Canvas?
Reply 8 of 22, by sndwv
lolo799 wrote on 2024-01-17, 10:37:
Pcmcia to usb enclosures work only for storage. Scp-55 has official drivers for dos/win3x/win9x and 3rd party support for a real […]
Thanks for the info! The SCP-55 might still be a cool thing to have for an old laptop to play around with, but indeed not really for his build. Also they seem to be near impossible to find, unfortunately.
I'm looking into the PMA-5 option now. I noticed that surviving ones likely need replacement (or for game-only use, desoldering) of the internal battery.
Reply 9 of 22, by RetroGamer4Ever
sndwv wrote on 2024-01-17, 13:07:
The X2GS (Second Edition) is a wavetable board that can be put on a soundcard or put in an external casing (also sold by the same maker) with audio outputs and connected via USB, to act as an external synth module. It is considered to be an acceptable replacement for an old Sound Canvas module. The First Edition of the X2GS is pretty much the same, except it has a headphone/speaker jack and may be closer to what you want, though it's been discontinued.
Reply 10 of 22, by AppleSauce
Yeah there's a soundcanvas munt equivalent emulator out there but its still being worked on and it'll probably be a while before it works seamlessly.
Once its done chances are someone will probably make a pi-hat type device for it.
Reply 11 of 22, by RetroGamer4Ever
For your particular setup, a good choice would be one of the old portable Edirol (Roland subsidiary) Studio Canvas modules or one of the portable Yamaha XG modules, both of which are still readily available for purchase on eBay and other such sites.
Reply 12 of 22, by sndwv
AppleSauce wrote on 2024-01-17, 13:54:
Yes, I've been watching that project. Would simplify things a lot!
Reply 13 of 22, by sndwv
RetroGamer4Ever wrote on 2024-01-17, 14:01:
Is there a specific or example module you'd be thinking of? Keeping in mind that I'm looking for SC-55 compatibility. That said, I won't be bothered if an instrument or two sounds slightly different, or if there would be a compatibility issue with <5% of games.
Reply 14 of 22, by RetroGamer4Ever
sndwv wrote on 2024-01-17, 14:23:
Well, if you're pushing for compatibility, then the Sound Canvas SC-8820 is probably your best pick, if you can't get one of the SC-55 types. It was one of the last to include SC-55 mapping. By the time the Studio Canvas units came around, Roland abandoned the synth maps used in the Sound Canvas line and simply adopted "The GS Standard", for it's products, which is why MIDI made for the SC-55 sometimes has to be edited to play properly on newer hardware, as the sound maps are different and do not fully line up.
Reply 15 of 22, by sndwv
RetroGamer4Ever wrote on 2024-01-17, 15:53:
I am currently using a SC-50 for my main PC. Also have a SC-55 Mk.2 in sorry state, but I always thought the SC-50 was essentially the same, sans MT-32 sounds. But for a portable build they are a bit cumbersome (and precious) to lug around, which is why I was looking for something you can throw in a bag, and is battery or usb-powered. So that's why the PMA-5 sounds interesting (though it is unclear how close it is to a SC-55), or perhaps a smaller or lighter 'desktop' module.
Reply 16 of 22, by RetroGamer4Ever
The SC-8820 is small and lightweight, so it fits your basic requirements, but the Dreamblaster x16GS in an external CHILL casing would give you the most quality and portability. For "checks all the boxes", the best choice would be a first-version X2GS in the matching shell-case.
Reply 17 of 22, by sndwv
RetroGamer4Ever wrote on 2024-01-17, 16:18:
Thanks, I'll check out the 8820!
What is 'better' on the first X2GS compared to the current(?) one? I'll check out some videos, it's still not completely clear to me how these attach and how they show up under Windows.
The cases for these are the 3d printed ones by Serdaco, right?
Reply 18 of 22, by lowe0
Yeah, this is still one of my wish-it-existed products. A USB Audio class-compliant device with a wavetable header on board; drop in a Dreamblaster X2GS and go. One USB cable back to the host, one power cable, one mixed audio out. Bonus points for a headphone amp - just enough to drive ordinary gaming headphones is fine.
Reply 19 of 22, by RetroGamer4Ever
sndwv wrote on 2024-01-17, 16:25:
Thanks, I'll check out the 8820! […]
The first version of the X2GS has a speaker/headphone jack, so it's ideal for your use. The second has improved onboard audio components, but it is meant for soundcard use and has no audio outputs. It's unlikely you will obtain any of the first version units, unless someone wants to sell theirs, for whatever reason. It's more profitable for Serdaco to make the X16GS and sell it with an interface board and enclosure, so the first edition design will likely never be made again, unless he chooses to do so.
