First post, by Martli
- Newbie
Hi everyone, long time lurker here, hoping to share with you some of my retro PC builds when I get a bit of time to write them up. This community has been a great help, and I'm hoping you can help me with something I haven't seen any other threads on.
I bought this Axra "Yamaha 3d sound" card which uses the Yamaha YMF719E-S chip. The card is in immaculate condition and came with the box and everything (see pictures attached). The driver CD comes packed with a Premiere "something about you" music video and the card apparently has an 'I-phone' connector 10 years before the iPhone even came out, talk about future proofing... anyway I digress.
I'm running this card in a SS7 set up. Pentium MMX 166 CPU, Asus p5a mobo, 32mb SD ram, S3 Virge GPU. I have Dos 6.22 and Win95 on separate CF cards. I have a Roland SC88ST Pro external MIDI device and a Roland UM-ONE midi-USB cable to connect to a laptop for external midi also.
This card replaced an ESS Audiodrive that was functioning as expected. The audiodrive was hooked up to my external MIDI devices via the gameport, and with some help from SOFTMPU this has been working fine. Great in fact.
For simplicity's sake, let's just focus on my experience in DOS, but I should note I experience the same issue in both DOS and Windows 95.
I installed drivers and set up my mixer settings using the helpful guide here here. The FM synth works great (sounds great too), as does the wave. CD Audio is a bit quiet, but I can probably live with that. Not sure about the WSS, I don't know enough about it, I need to solve this issue before I can test that though....
I am having major issues with the MPU-401. It appears I'm not getting any signal from the card to my external devices hooked up via the gameport. I've tested this using the duke3d set up utility. I get the message saying "you should here the duke nukem theme song" suggesting it's found the right port address and located the MPU-401, but none of the LEDs light up on my Sound Canvas, and there's no sound. In Windows I've set the MIDI instrument to 'external device' and I get nothing when I play Canyon.mid.
To be double sure sure it wasn't a fault with my cable/external devices I reinstalled my ESS audio drive and, lo and behold, everything operated as normal.
I tested out a joystick to see if it's a problem with gameport itself, and the joystick worked fine.
I've now installed both the ESS Audiodrive and the Yamaha card, with the audiodrive handling the MPU-401 and the Yamaha doing everything else, but it seems like a waste of an ISA slot to have two very similar cards in there. The main reason I got the Yamaha was to eventually pair it with an SB16 or AWE64, but I'm probably going to go back to my trusty Audiodrive for the time being.
The only thing I can think of at this point is that it's somehow sending everything to the wavetable header but not the gameport? I'm not sure that's actually a thing. Unfortunately I don't have a wavetable to test out (and I'm not going to buy one for the sake of this card).
I suspect this is just a faulty card, but before I admit defeat and try my luck buying a replacement, has anyone else come across a similar issue with on one of these cards? Is there anything else I could try to get this thing working? Thanks in advance.
Fenrir Asus P5A | Pentium MMX 166 | Ymf719 | ES1868f | SC-88ST pro
Neptune Asus P3B-F | PIII 600 | Voodoo3 | Audigy 2 | SB16
Thor Intel D865GBF | P4 3.0ghz | 4200ti | Audigy 2ZS
Jupiter Intel DH77KC | i5 3470 | GTX 670 | X-Fi
